Icom 8500
ACL
Hi. I currently own an Alinco dxr8e for MW and HF dx and an AOR 8600 for vhf/uhf dx. I'm considering trading these in for a 2nd hand like new Icom r8500.Has anybody got any suggestions as to whether this would be a good move or not? Would it perform as well or better then my current set up in the respective frequencies mentioned. Thanks.
higinbotham
Seminole, FL
Technology is changing. But I am assuming that your like me. Not being able to purchase new and latest. I happen to buy the ICOM R-8500 years ago. But I found that the unit drifted a little in the higher range and I need the stable crystal upgrade and the default filter capability seems lacking. Maybe you might upgrade to later version of present AOR radio.
Read this - receiver-reviews
AOR 8600 MKII - http://www.monitoringtimes.com/html/mtscan1002.pdf
ICOM R-8500 http://www.monitoringtimes.com/html/mtscan0804.pdf
airwolfbell222
Central North Carolina
Having had both Icom and AOR, I'd keep the AOR and Alinco, I think you're better off having a dedicated VHF/UHF & HF rig as oppose to having both combined. Plus you have a portable unit right now in the AOR if needed, the Icom 8500 is a boat anchor and don't expect to ever move it.
n2pqq
I would also keep your current radios.
Alinco has a better hf receive then the Icom.
I have owned a Icom 8500 and currently own a Alinco dx-r8.
The alinco is a hot receiver for the price.
Between the built in preamp the if shift and the rit you have a better chance of hearing that elusive signal.
Turbo68
East Devonport,Tasmania,Australia
Hi main intrest for me is monitoring aircraft I do have both receivers and performance is excellent youre better off having 2 receivers and its easier to monitor lots of signals then rely on one to do every thing.
What antennas are you using for hf & vhf..
Regards Lino..
