Yaesu FTA-850 AirBand Transceiver - Remarks
Have no previous experience with AirBand receivers or transceivers, only for the purpose of receiving AM modulation - no FM, WFM, SSB, CW etc.
Was looking for a radio with the sole purpose of receiving AM in the civil aviation frequency range, so was a choice for me between Yaesu and ICOM, since I have good experience with both Yaesu and ICOM previously.
And the Yaesu FTA-850 it now is.
But must must admit from the first couple of days owning this radio, I wish I've bought anoter model / brand.
A bit of a disappointment the FTA-850 I have to say.
*** Remarks ... ***
*** Positive ...
- Nice large color display.
- Antenna connector is BNC.
- Separate Squelch button.
- Separate connection for data / USB cable, no adapter or other cables needed.
- Comes with adapter for headset, and possible to have a dedicated PTT switch.
- Comes with USB programming cable, even though it is the ancient and terrible Micro-USB standard.
- Comes with cigarette-lighter cable to provide charging and receive capability in the car.
- Comes with a cassette for alkaline batteries which comes in handy when charging the lithium battery is not available.
- Feels like a radio, has a bit of weigh to it and feels good in the hand.
- PTT can be disabled when used for receiving only.
*** Not so positive really ...
- Display and keyboard never turns off, always on /dimmed - no setting to have the display / keyboard off when no signal is received.
- Volume can't be turned all the way down, on lowest level, noise is heard in the speaker when squelch is open or signal received on frequency / channel.
- Charging cradle / pod can't hold a battery for charging - unless it's installed in the radio, so no way of charging extra batteries while using the radio - problematic when having spare batteries.
- Problem using the YCE46 CPS to read / write data from / to thenradio.
Receiving the error message "Timeout!! (FirmVer)" when trying to communicate with the radio through the USB cable with the YCE46 CPS.
Tried from Windows 10 Enterprise 64bit and Windows 7 Pro 64bit - receiving the same error message.
Have tried different speed setting for the COM-Port (Serial USB driver installed together with the YCE46 CPS, during the installation process).
Problematic when having to program more than 300 channels with coordinates into the radio.
No other error messages received.
- There's no Microphone Gain setting available, neither in the CPS or in the radio.
- There's no RSSI type indicator or bar type indication of received signal level.
There's only a BUSY indicator shown when a signal is received.
- The USB socket in the radio - is Micro-USB.
Who installs Micro-USB in anything in 2021 ...
(Year from the firmware in the FTA-850).
