icom accessory port screw hole
matt131
This may sound like a silly question but has anyone had any problems with stripping the screw hole on the icom accessory port if you were to take on and off a speaker microphone or an other accessory many times?
If it were to become stripped is it easily repairable?
jeatock
090-45-50 W, 39-43-22 N
I have had problems with customers using a oversize screwdriver and 3-foot cheater bar "snugging" up those 2MM screws and torquing them off in the threads, but never a problem with normal finger-nail torques stripping them out.
Depends on the model- some connectors screw into the case ($$'s), some screw into the frame casting ($$$$'s) and some screw into an independent component ($'s).
I recommend that customers torque them using a fingernail only. If they insist on a "tool", I suggest folding one out of paper. That way they don't get too tight and break.
