ICOM CS-F30G
KI7FSE
Usk, WA
I am programming a ICOM CS-F30G Portable with the necessary software. I can Transmit on this Portable into a Digital Repeater and the Conversation can be heard. But on the same Portable, I cannot receive a Transmission from the same Digital Repeater. I have checked and the Frequency and CTCSS is programmed correctly. Any suggestions? Thanks
12dbsinad
The F30G is an analog only portable not capable of digital. It sounds like you are using the analog side of a digital capable repeater.
First, try setting your RX CTCSS to "off" (CSQ)
Are you receiving a signal after you release the PTT (green RX light/ RSSI bars)?
Start here first. This is assuming your radio does not have an actual failure.
KI7FSE
Usk, WA
Thank you. I did set the RX CTCSS to "Off", Yes I am hearing the signal after I release the PTT. I can transmit to a Digital Repeater, the problem was receiving from the Digital Repeater.
12dbsinad
What are you hearing with the CTCSS is set to off? Just a dead analog carrier or digital hash noise, etc?
