Icom F3161t question
andy3940
If I buy the icom UT-126H digital chip for my radio will my current programing software support it?
Andy3940
n1oty
Taunton, Ma
If you have the programming software...........
Andy3940
.............for the 3161, it does not matter whether the radio is equipped for digital or not. One piece of software programs the radio for digital or analog operation. Get the module and pop it in.
andy3940
Another question
This f3161t and f3161 model I own (one with DTMF keypad) one with out is not working with my computer software. I'm using a usb to serial adapter and have it set up using the icom driver software following all instructions. I followed the directions and it set up the icom driver on comm port 9. i then turn on the radio and open the software and attempt to read the radio. I then get the icom error screen that says it can't detect anything. I'm using 2.7 ver software. Any ideas??????
ElroyJetson
There was a transition a while back. The early 3161s don't use the same software as the newer ones. The correct software for a newer one is the CS-F3160_F5060 software package.
I believe the earlier ones used the CS-F3060 software package, which is not usable with newer radios.
To ensure that the digital option board works properly, you need recent firmware as well.
No jumper pads need to be altered to make the digital option board work but the firmware has to be
sufficiently up to date.
CJ
