Icom F33GS Tone Alert
rescuecomm
Travelers Rest, SC
I got mine setup for two tone alert and it works just fine. Now, I have looked through the "button" function list and I don't see anything to stop the "beep-beep" so I can clearly hear dispatch. I have to turn the radio off and on to clear it. Any suggestions?
Bob
stevelton
I have my side button above the PTT set as Moni.
Pressing this once while beeping will stop the beep. Then when dispatch is finished, press and hold should take off the open sqelch and return that channel to quiet stand by.
Steven
gmrsoutlet
Oswego, IL
You can set a reset timer on the channel as well.
The "Auto Reset" field on the channel row. Default is likely Tim-B. You change the time of "Tim-B" under the Common Section in the software. By default Tim-B is "off".
It is a idle timer. So once a 2-Tone activates the radio, the timer starts. It is an idle timer, so once there is no traffic on the channel for the time defined in the Tim-B setting the channel will reset. If there is traffic on the channel beforee the timer runs out it restarts the countdown.
