Icom F40GS
jtech48
OVB
I Recently Bought A New Icom F40GS and came with programming software (CS-F30G). I am wondering if theres a way to enable a data burst or roger beep on the radio, I couldnt find any option on the software itself that said that, but maybe I missed it and the help tab on the program just opens the wndows help, any help is appreciated thank you
loumaag
Silent Key - Aug 2014
Katy, TX
Moved to the proper forum. Please don't post professional radio questions in the receiver's section.
stmills
Twin Cites Area MN
Here is what I have used on my f40gs
1. DTMF Autodial
LOG/ID enter a DTMF ID hear
2. DTMF Settings
DTMF Timer
I have mine set to 0.020
3. on the channel edit screen
field LOG can be :
OFF - No ID is transmitted with the [PTT].
L-IN - ID is transmitted each time [PTT] is pushed.
L-OFF - ID is transmitted each time [PTT] is released.
Both - ID is transmitted each time PTT is pushed and released.
jtech48
OVB
Thank You, I didnt change some of the options you did since I wasn't sure what they did. Ill try your selections
b7spectra
EMS Dispatcher
Cobb County, GA
I've got the 40GT (different than the GS - this has full keypad), and in the software under Common/Set Mode, I have tried the SQL Level from 1-9 and I still get an open squelch on the 1 channel that doesn't have a PL set. Anyway to reset the squelch so it goes away on this channel? On all the other channels, there is a tone set, but the green light stays on.
jtech48
OVB
Set it to 155, at first I thought it was 1-10 also but it actually goes up really high, I have mine at 155 and its perfect
stmills
Twin Cites Area MN
I run my 40 gt & 40 gt at 105 and have good luck with a couple of carrier channels, I tried down into the 90's and had open squelch issues. When I got my gt I couldn't figure out why the sensitivity was so off my other radios, and was direct to this setting by this board- my radio came with a setting of 300.
b7spectra
EMS Dispatcher
Cobb County, GA
An odd problem I came up with is I was using the rotary knob for channels and P3 for banks. When I would push the P3 button it would show what the current bank is and I can not change them. Same also goes for the SCAN lists. I have two scan list and when I push P0 (for scan), it only does the 1st list. This portable isn't as user friendly as my F5061!
