Icom F50 options
pantegra
I am trying to setting up the software for a radio. The issue I am having is when entering in the frequencies I only have the option for narrow band. I need to be able to select the wide band option for one of my channels. Is there a different serial number I should be using or an option in the software?
Thanks.
12dbsinad
If its a newer radio, it is resticted in the firmware. All Icom radios capable of wide and narrow operation are shipping with narrowband only firmware. It becomes an issue if a ham wants to use the radio on an amateur frequency for example as it would be narrow only.
pantegra
Even though I have only installed the software? The programmkng cable is on its way. I am just trying to get all the frequencies plugged on before it gets here.
stevelton
Work with your dealer and ask him to get you the older firmware. Write that to the radio, and that should fix it.
Steven
Project25_MASTR
There's stuff I can't tell you...
Texas
I wonder if putting be cs in maker reserve mode will let you change it. (I'm not gonna tell you how to do that, it can be found online though).
My cs-f3021 software isn't narrow only, just narrow default.
12dbsinad
Software and firmware are 2 different things. Even if you select wide on your software, the newer firmware will allow narrow only, regardless of your software setting.
DO NOT mess with the maker reserve settings. The only thing it will lead you too is trouble...
Project25_MASTR
Texas
Just a curiosity seeing that I've used maker reserve with cs-f11 to program non gmrs frequencies on the F21GM.
Sent from my ME173X using Tapatalk
W2GLD
Senior Member
SE Michigan
Do not ask the dealer for older firmware. If you are an authorized wideband liveness; ICOM has utilities to make the radio FM and NFM compliant available. When the tool is run on the radio, you will need to fully align the radio with a service monitor to insure that the audio levels and so-forth are configured properly for FM operation.
Even if you back-date the firmware down, the radio is still locked in NFM ONLY mode... This is locked in hardware and CANNOT be changed with a simple firmware downgrade.
Contact your ICOM dealer and they should be able to help you with this.
