Icom F5062D Repeater Connection Modification
bradlington
South Africa
I would like to make a mixed mode repeater using the chassis boards only - run analogue (CTCSS enc/dec) along side with IDAS as mixed mode operation on a single channel .
I would like to use the board only without the head.
If I switch radio on and then remove the ribbon going to head ,the radio remains in operation until power is reset .
Ideally use the given dB25 for inter connection .
Anyone done this before where the chassis are used in stand alone , one for RX and one for TX - each has the UT-126 IDAS board .
Thanks in advance
Bradley
bradlington
South Africa
Some feedback on the project - so far analogue channel and idas channels are both working as a back to back repeater .At this time I do not see how the repeater could do mixed mode due to no control from repeater mobile RX to the repeater TX .At least it is working in dedicated modes.
I only bridged Link N in the TX for audio routing .
Ground pin 7
Rx pin 1- via diode to TX pin 19
Rx pin 10 -via pad resistors to TX pin 8
Although individual idas ID's will not pass the TX ID shows up on mobile during idas channel and tail .
bradlington
South Africa
Updated-I have found a way to field frogram this radio and works very well .
Only Zone1 is able to be changed, but any frequ/ ctcss user data etc as well as idas user can be changed from front keypad .
