ICOM F5201 and 2 meter?
mjz55
PA and NJ, USA
Is it possible to add a couple 2 meter ham frequencies to this radio? I know it's not considered a ham but is it possible and if so, how do I set it up in programming?
KD0LDK
Wichita, KS
Looks like the frequency range is 136-174, assuming you have a HAM license you should be good to go.
stevelton
First, type in the frequency you want to receive. Then type in the frequency you want to transmit, then type in or select from the list the pl tone you may or may not need to transmit, and boom, there you go.
I use the F5021 for 2m ham all the time.
Steven
KD0LDK
Wichita, KS
There should be a receive and transmit input. You'll have to determine what the offset is for the frequency. 2m is always .6 mhz.
Kyle
mjz55
PA and NJ, USA
I have offsets of 6.73500, 1.50000, 7.87500, some of the Marine Bands have Offsets of 4.60000 and also some other frequencies have offsets of 600. I'm using the CS-F3020/F5010/F5020 Revision 3.2 software. I imputed the RX and TX frequencies and selected narrowband. I also added the C.Tone RX and TX. I don't see where to do anything with the offset Frequencies I mentioned above. This is my first time doing this.
KD0LDK
Wichita, KS
Hmm, I can't really picture the software. Anyway you could take a screenshot of it?
You should be able to manually input the RX and TX frequencies without messing with pre-determined offsets. 2M ham offset is always .6 Mhz, it just depends whether it's + or - .6mhz
- Kyle
mjz55
PA and NJ, USA
Yes I can input rx and tx frequencies. May be a stupid question, but must I add or deduct from the frequency for frequency offset and input to rx and tx?
KD0LDK
Wichita, KS
Yea you'll have to do it manually. Now obviously if you're running a simplex channel, they'll have the same input/output. Here are the standard offsets.
2-Meter Repeater Output Frequency Standard Input Frequency Offset
145.1 MHz - 145.5 MHz -600 kHz
146.0 MHz - 146.4 MHz +600 kHz
146.6 MHz - 147.0 MHz -600 kHz
147.0 MHz - 147.4 MHz +600 kHz
147.6 MHz - 148.0 MHz -600 kHz
Source: Standard 2-Meter Amateur Radio Repeater Input Frequency Offsets
mjz55
PA and NJ, USA
Sorta kinda. Maybe if I give you an example. I'm taking the info off a IC-V8000 programming list. It has Receive Frequency of 150.7000 with offset frequency of 7.87500 Transmit Frequency of 142.82500 and Offset Direction of -DUP with No Offset Reverse.
Would I set both RX and TX at 142.82500?
KD0LDK
Wichita, KS
Well it depends what you're trying to do. 150.7 is a commercial frequency not a HAM frequency. If you don't want to operate on a repeater, make the RX and TX the same. If you're operating on a repeater you'll need to factor in the .6 Mhz +/- offset. Amateur radio on 2M will ALWAYS have .6 Mhz offset, nothing else.
As an example. The local Manhattan, KS repeater is KS0HAM operating on 147.255 with a PL tone of 88.5 Mhz. This frequency advertised is the RECEIVE. Now, looking at the key I provided 147.255 qualifies for a (+) offset. So your settings would be as follows..
REPEATER CALL: KS0MAN
RECEIVE FREQ: 147.255
TRANSMIT FREQ: 147.855
PL TONE: 88.5 Mhz
