Icom F6061D Speaker Outputs
W2TFD
Terryville, New York
Is there a place in the software to only select the remote speaker output? I have been looking but can’t find it.
12dbsinad
You must be using a remote kit on the radio because in regular configuration it mutes the head speaker. When using RMK it will not if plugging into radio body. Your options are either to plug the speaker into the head jack and not the radio body, or unplug the speaker.
W2TFD
I saw in the 5051D RR SOFTWARE a reference to speaker 1 and speaker 2, I was wondering if there was the same for the 6061D. I did look in the software but couldn’t find it. Disconnecting the speaker inside is next. Thanks
12dbsinad
Takes about 2 mins.. 4 screws, pop the cover off and locate the yellow speaker wires going to a small connector near the rear of radio. Unplug and make sure to secure the wire/connector. Replace cover and done.
