Icom F60v
RadioTech013
I have be working on group of portables the f-60v's and i have 1 in the group that will read but can not write any idea why, all other radio will read and write.
12dbsinad
The older F60v's did not have minitor mimic "MM" and used regular f60v software. If it's a newer unit or a unit with upgraded firmware it requires the F60v MM software. If you try to program it using the opposite software it will do as you describe read but not write. Check the radio in question by pushing the up arrow and P3 together and power on the radio, it will scroll thru the version that's in the radio. The latest version is 3.6.2 MM.
