Icom F7010 series P25 Subscriber Radio Information
W2GLD
Michigan
This thread is to highlight accurate and detailed information related to the latest Icom F7010 series P25 subscriber radios. All F7010 series radios are official DHS CAP certified as of October 2019.
The following models are included in the F7010 series:
IC-F7010S Limited Keypad VHF 136-174 MHz Portable
IC-F7010T Full Keypad VHF 136-174 MHz Portable
IC-F7510 VHF 136-174 MHz Mobile
IC-F7020S #11 Limited Keypad UHF Range 1 380-470 MHz Portable
IC-F7020T #21 Full Keypad UHF Range 1 380-470 MHz Portable
IC-F7020S #31 Limited Keypad UHF Range 2 450-512 MHz Portable
IC-F7020T #41 Full Keypad UHF Range 2 450-512 MHz Portable
IC-F7520 #11 UHF Range 1 380-470 MHz Mobile
IC-F7520 #21 UHF Range 2 450-512 MHz Mobile
IC-F7040S Limited Keypad 700/800 MHz Portable
IC-F7040T Full Keypad 700/800 MHz Portable
IC-F7540 700/800 MHz Mobile
Upgradable Feature Enhancements Licenses:
ISL-P25TR Phase 1 Trunking Operation
ISL-P25P2 Phase 2 Trunking Operation (Requires ISL-P25TR)
ISL-P25DS Data Services (Required for Tier-1 & Tier 2 Location Services)
ISL-P25AES AES256 Encryption Enhancement (Requires UT-134 or UT-125FIPS-2 board)
ISL-P25VS Conventional Voting Scan
ISL-P25W 25.0 kHz Wideband Operation (Requires FCC authorized license within the United States)
Assorted Hardware and Software Options:
UT-134 AES/DES Encryption Hardware Board (Requires ISL-P25AES to remain DHS CAP compliant)
UT-125FIPS-2 FIPS 140-2 Compliant AES/DES Encryption Hardware Board (Requires ISL-P25AES to remain DHS CAP compliant)
BC219N Standard Single Unit Rapid Desktop Charger for North America
BC225 Smart Single Unit Rapid Desktop Charger for North America (Optional RS-BC225 Battery Management Software available - supports up to 30 connected chargers)
BC214-1 Standard Six Unit Rapid Desktop Charger for North America
SS-BC62 Standard Vehicular Charger with Cigarette Adapter
IABC1019 Heavy-Duty Single Unit Vehicular Rapid Charger
BP284 Standard 3210mAh Lithium-Ion Battery Pack (Same as supplied with F7010, F7020 and F7040 portables, MB133 Standard Belt Clip not included)
MB133 Standard Belt Clip (Same as supplied with F7010, F7020 and F7040 portables)
OPC1534 Encryption Keyloading Cable for Motorola KVL3000/4000/5000 (Requires female-to-female RJ-45 adapter and OPC1871 adapter for Portables and IAOPC1075 adapter for Mobiles)
CS-F7510 Radio Programming Software
OPC2338 14-pin USB Programming and Transparent Data Cable for Portables (Standard micro USB 2.0 cable also supported with specialized driver installation)
OPC2363 10-pin USB Programming Cable for Mobiles Front Panel Microphone Connector (Standard micro USB 2.0 cable also supported with specialized driver installation)
CS-OTPM2 Over-The-Air Programming Software (OTAP) for Conventional Operation Only (Important Note: OTAP for trunking is not supported at this time)
UX-241 Magnetic Mount GPS Antenna for Mobiles (Required for Tier-1 and/or Tier-2 Location Services)
RMK5 Single Remote Head Mount Separation Kit (Requires selection of appropriate OPCxxxx extension cable)
RMK7 Dual Remote Head Mount Separation Kit (Contains additional Remote Head, Requires selection of appropriate OPCxxxx extension cables and secondary microphone)
HM218 COMMANDMIC Remote Control Head for Mobiles (Allows for installation of radio in smaller vehicles, remote head unit is similar to the F7010 series portable size, shape and functionality - allows for reduced training between portable/mobile models)
OPC2364 6.2ft. (1.9m) Remote Head Separation Cable (Requires either RMK5 or RMK7)
OPC2365 9.8ft. (3.0m) Remote Head Separation Cable (Requires either RMK5 or RMK7)
OPC2366 16.4ft. (5.0m) Remote Head Separation Cable (Requires either RMK5 or RMK7)
OPC2367 26.2 ft (8.0m) Remote Head Separation Cable (Requires either RMK5 or RMK7)
OPC2373 6.2 ft (1.9m) Remote Head Separation Cable for use with HM218 COMMANDMIC (Requires either RMK5 or RMK7)
OPC2374 26.2 ft (8.0m) Remote Head Separation Cable for use with HM218 COMMANDMIC (Requires either RMK5 or RMK7)
HM220 Standard Heavy Duty Mobile Microphone (Same as supplied with F7510, F7520, F7540 mobiles)
HM220T DTMF Heavy Duty Mobile Microphone (Same as supplied with F7510, F7520, F7540 mobiles)
SM29 Desktop Microphone for use with F7510, F7520 and F7540 Mobile as Control Station
IAPS12 Desktop Power Supply with Custom Cover for use with F7510, F7520 and F7540 Mobile as Control Station
SP30 20W External Speaker for F7510, F7520 and F7540 Mobile
FAS81V 136-150 MHz Standard F7010 Portable Antenna
FAS82V 148-162 MHz Standard F7010 Portable Antenna
FAS83V 160-174 MHz Standard F7010 Portable Antenna
GAL06026 136-174 MHz Optional F7010 Wideband Portable Antenna (Recommended for use with Large VHF Statewide Trunking Systems or customers requiring wide-spectrum coverage)
FAS81U 380-430 MHz Standard F7020 Portable Antenna
FAS82U 430-480 MHz Standard F7020 Portable Antenna
FAS83U 470-520 MHz Standard F7020 Portable Antenna
FAS100U 700/800 MHz Standard F7040 Portable Antenna
HM222 IP68 Waterproof Speaker-Microphone for Portables
HM184H Windproof Speaker-Microphone for Portables
IAHM600 Heavy Duty Bluetooth Speaker-Microphone for Portables
IASKF7P System Owner Master Key (SOMK) Required for Trunking - Requires Special Authorization Form from Trunking System Owner/Administrators and Icom P25 Engineering Group (Only Available to Trunking System Owners/Authorized Administrators)
IASKF7S Accessory Advanced System Key (AASK) Required for Field Programming of Trunking Parameters (Non-Provisioned - Requires Trunking System Administrators Authorization and Activation)
Current Software/Firmware Versions as of October 2020:
Radio Firmware = v3.9
CS-F7510 Programming Software = v2.90
CS-F7500ASK Advanced System Key Manager Software = v2.1.126 (Only available to trunking system owners/authorized administrators)
Radio Discovery Tools (RDT) = v2.1.70.0 (Home | IcomRDT)
Some General Notes:
  1. When ordering F7010 or F7020 model portables, you must specific the requested antenna option for the required operating frequency range, no antenna is included by default except for the F7040 700/800 MHz models.
  2. To utilize Radio Discovery Tools (RDT), a properly formatted microSD card is required and the radio must be configured with the appropriate settings through programming.
  3. Trunking enabled radios can be programmed without requiring an ASK in order to make conventional and configuration changes; however, you will not be able to add/modify ANY trunking parameters without an "authorized ASK for the associated trunking system".
  4. The IASKF7S Accessory Advanced System Key (AASK) for trunking operation can be purchased by anyone; however, they are non-provisioned (unprogrammed) and authorized programmers are required to have the ASK programmed and authorized by the trunking system owner/authorized administrators. (Note: this requires the trunking system owner/authorized administrators to have secured the required IASKF7P (SOMK) first, through the approved processes.)
  5. For Phase 2 trunking support, the ISL-P25TR Phase 1 licenses is required.
  6. For Over-the-Air GPS and Android Tactical Awareness Kit (ATAK) support, the ISL-P25DS licenses is required.
12dbsinad
These radio's are an excellent cost effective solution. A lot of bang for your buck.
Skypilot007
Medford, NJ
Can the general public purchase these from a dealer? Are these capable of non-affiliate trunk scan? Inquiring minds want to know!
W2GLD
Michigan
They are available through dealers but they will not do “non-affiliated“ operation. An “authorized Advanced System Key” is required for all trunking programming, including the ability to simply view the radios trunking parameters. These radio are capable of RX Only talkgroups, but are still required to affiliate on the system. These are not scanners for the general public, several safe guards have been put into place to prevent that operation in order to protect the trunking systems integrity.
