Recently purchased the ICOM ic-2730a from DXEngineering and a USB-29A cable from GigaParts RT Systems USB-29A
When the cable came in, I attempted programming via CHIRP as well as through the supplied CS-2730 software. Neither of which have worked. (Drivers supplied with cable have been installed)
CHIRP: "Failed to communicate with the radio: Out of sync with radio" or just fails to connect
CS-2730: "Cannot access COM [x]" - whichever com port the cable is attached to
What's the verdict? Bad cable, incorrect cable?
I have the cable connected to the radio before booting, connected to the speaker port closest to the center of the radio, then I boot the radio and open the software, before getting the error. Is there a setting or a procedure I missed?
Thanks!
Thanks!
