ICOM IC-F121 Any Reviews?
KJ4LZG
Can anyone assist me in getting the 1.7v or the IC-F100 Software? Any help would be appreciated.
groominator
Same concern about 121
I am new to programming the F121. I am setting these up in 4 of our ambulances. They seem to work fine. I have the scan turned off when the radio turns on. I have buttom 1 programmed to start or stop scan. The scan works properly without the mic being grounded but it shuts off after about 2 minutes, why? I am also wondering what everyone is using for SQ level. I started at 45 but im not sure that is best. Can anyone tell me there common setup that works well for their total setup,
Thanks for any help.
Steve
silverbk
Steve
To hook scan is a very annoying feature of the Icom. The radio will not continue scanning without the mic hung up. I don't know why they have that feature but they do. The only way around it is to wire the microphone so it's grounded all the time (which I do not recommend).
On the sq the default values should be fine unless you move into a very rf intensive area.
The only setting you may want to change is the minimum volume value. I purposely setup my public safety radios so the volume cannot be turned all the way down to zero. I have seen a lot of calls get missed because guys turned the radio down to talk on the cell and did not turn it back up. A little experimentation will get you a value that can be heard but not blaring.
igushikman99
igushikman99
I just bought F121 and everything works fine, except scanning.It only works with a PL 2303 cable plugged to the radio and with other end only disconnected (just loosely hanging).With a mic grounded or not does not work.Thank you for any help.
Mirek.
igushikman99
igushikman99
I set hanger action to ON and OFF with same unsuccessful result.Once again it only scans with cable PL2303 connected to radio and on the other end disconnected from computer.
