Icom IC-F2100D IDAS NXDN - looking for recent codeplug (Revision 1.6 etc) to recover corrupted radio
g8tzl2004
I have an Icom IC-F2100D NXDN radio which has a corrupted codeplug.
At boot up the radio has a constantly blinking green and red LED which indicates a corrupted codeplug.
I need to upload a matching codeplug from another identical F2100D (basic version with no LCD or keypad) to recover the corrupted radio.
My Icom IC-F2100D radio has a serial numbers beginning with "640xxxxx" and uses a Revision 1.6 codeplug.
I have successfully recovered a "Revision 1.2" IC-F2100D radio with the same red/green flashing LED by using a codeplug from an identical Revision 1.2 radio with a serial number starting with 620xxxxx. Unfortunately I don't have another F2100D which uses a Revision 1.6 codeplug( and has a serial number starting with 640xxxxx). Serial numbers before 640xxxxx might also have a Revision 1.6 codeplug if the firmware has been updated. A later codeplug after Revision 1.6 might also be OK?
Hopefully somebody can help out?
I'm not sure if writing new firmware will recover the corrupted F2100D but I know that writing a Revision 6 (or later??) codeplug (checksum $9A89 from the info screen) should work as it worked with a corrupted Revision 2 radio.
