ICOM IC-F221S voltage range
serial14
I have some IC-F221S radios. I can't find any spec for the input voltage range/tolerance. Does anybody know? The data sheet simply says 13.6Vdc and nothing else.
13.6 +/- 10% is often what you'll see for commercial gear.
Not uncommon to see 14.5v in a vehicle if the alternator is working hard, and not uncommon to see around 12.0 when cranking/cold, etc. You may find it's not happy down towards 12.0v though.
wd8bdn
I did a peeky look and found NOT over 16vdc. I'd take mmckenna's data for real. I run a '221S in the shack on about 13.2 off the powersupply
