Icom ic-f3021s Static
Gundulf
Puerto Rico
Hello !
I received an ic-f3021s as gift from a friend, and its making me crazy trying to program it. I can program the radio to the frequencies i want, but when i turn the radio on all i can hear is static, it shows like its always receiving a signal. When i turned the squelch up on the adjust tool i can make it better so its not always receiving a signal but then i get no transmission at all. Also i can barely understand the transmission I'm getting since it is full of static, i have to turn the speaker very high in order to understand something out of the static. what setting should i be looking at as the culprit? Btw thanks in advanced.
R
radioanswer
Guest
F3021s
Hello !
Hi,
The F3021s has two version Rev1.5 and the latest is Rev 3.2.
The Rev 1.5 has a separate Adjustment software, you can use that program to adjust your squelch level around 100 level, Squelch level from 0-255 at 100 : -117dBM.
The new version Rev3.2 the adjustment software is intergrated into the main program, you can find in the Nav bar there is a red screwdriver icon, click on that to read your radio, then double click on Adjust to open the program, go down to squelch and adjust to level 4, because the new version squelch level is 0 to 9. 7db different.
To check your portabe radion verion:
push and hold P0 and P3 then power on if you see R 3.1 is a new version, if not it is Rev.1.5
HP
