PCR1000 ICOM IC-PCR1000 ?
Ubbe
Stockholm, Sweden
I have an icom pcr 1000 it works fine but I can't seem to get it to work with dsdfastlane.
If it works fine with the same computer and OS that you use for DSD_FL, then look at the settings in the program you are normally using to control the PCR1000 and copy the baudrate and other communication parameters and use them in DSD_FL. Just start your normal program and use the same cable and check that it works and then close that program and start DSD and configure its communication protocol.
Or is the audio decode that doesn't work, then you have to use the packet output jack to get a proper audio signal to decode. The dsdtune.exe program will automatically test out the proper setting to be used in DSD.
/Ubbe
Alpinaswiss
Thanks for the answers.
No dsdplus does not work, I have no sound. I connected the mono jack to the headphone output of my computer and to my discriminator output of my pcr1000
In analog it works well
Ubbe
Stockholm, Sweden
Then you probably have directed the Line in of your computer to go to the loudspeaker, in Win7/10. Then it's just a matter of setting DSD_FL to use that Line in signal. It's the packet output of PCR1000 you must use and not the speaker/headphone jack.
I do not have fast lane but in the DSD+ you just type dsdplus to start it and it will display what number each device has. If it says that line in use #2 and loudspeaker use #1 then then start with dsdplus -i2 -o1
Start CMD in windows and type dsd -h to get the proper syntax, or whatever the exe file are called in fast lane.
/Ubbe
