If you are not using it already, set the radio to use the RF gain and not the squelch control. This is what Ubbe is referring to. Adjust it to reduce the noise just enough and then back it up to hear what you want. You may need to turn up the volume after adjustment. Read up about it in the R75 manual as well (pages 14 and 30). This simple adjustment has helped many with their radios and the "white noise". Additionally, there is the UT-106 DSP Unit which is made for the Icom R75 and others, you can install into the radio which can also help. I believe they are no longer made, so you'll probably have to find one on eBay and they are probably $100+. Alternative to the UT-106 DSP and the other DSP units noted above there is the Radio Shack DSP. It is external to the radio and typically under $50 used. They may be found on eBay, eham.com, qrz.com and qth.com. You may need to search for a while.
I guess the best question to ask is,,If you had this Radio , What Antenna etc would you use for it?,,Need tips ?
If I had the R75 I would use a long wire with a 9:1 balun. I would also use a
W6LVP active loop with it. The loop can be turned to potentially tune out noise/hash, yet provide you with the signals you want. Some people have noise/hash coming from a specific location and are able to turn and leave the loop set in a particular position. Others need to rotate the loop based on their listening needs, as the loop is directional. I would just use a manual switch two choose each antenna, or you can unplug and switch. If I had to choose just one antenna, I would go with the loop for various reasons you can read up about in the
RR Wiki about loop antennas.
UPDATE: I should note that you may have RFI (Radio Frequency Interference) coming from your own location, or from your neighbors. You may need to hunt down the source if you are causing it. A wire or loop antenna and add on stuff may not eliminate the RFI. There are others sources of RFI as well like AM Broadcast stations, but there are filters for that too.
