dxace1
Seeking others who have installed Sherwood rear replacement panel with fan on IC-R9000.
Thanks. . . .
Thanks. . . .
I would save your time and money on that mod.Seeking others who have installed Sherwood rear replacement panel with fan on IC-R9000.
Thanks. . . .
Thanks for this extensive info. Any photo whatsoever would help . . .I did the same thing when I purchased my R9000.
For mine, I used a 120mm case fan with a 3 speed selector switch which I set on the s;lowest speed to minimize fan noise. It turned out moving plenty of air when I was all done.
I was able to work some tiny wire ties through the ventilation slots on the rear panel next to the heatsink. I wanted to try and remove any heat from the components like the CPU etc. Mine pulls air through the vent slots in the rear chassis. Not sure where it gets the air from as I've never discovered any dust accumulations when I open the radio up. I know it does pull hot air out though if I leave the fan off and power the 900 for 30 minutes or so. I get a decent amount of warn (not hot) air for about 10 minutes or so and then it cools to just above ambient temp.
I also used the 12VDC barrel jack power connector on the rear of the R9000. Running the fan on the slowest speed kept it pretty much inaudible for years now. But... the other day I started hearing an odd noise. It was my R9000 cooling fan. I removed it and opened it up and I was able to clean it very well plus lubricate it and pop it back together. It had a fair amount of dust buildup on the fan blades and some around the slotted vents on the R9000 rear panel but nothing alarming considering how many years the fan has been operating.
I don't know the model of fan but it's an older Antec model that has real ball bearings and a 3-speed switch. It also had the 3rd tachometer output wire for computer use which is not used of course for the R9000 cooling.
The whole thing used things from the misc parts bins to hold it in place over the R9000s vet slots on the rear panel.
After I mounted the fan using wire ties, it wanted to slip down as the wire ties couldn't be tightened really tight. So I took some thin pieces off hard but thin plastic from a case or project box or something and simply super glued them to the top of the fan. The plastic pieces rest on the top of the R9000s top cover and keep the fan from sliding down. They only overlap the R9000 top cover by a quarter inch
I can't even count how many years this fan has been running and had the bearings not dried out the other week, I really didn't know if it was running unless I worked my hand in back of the R9000 and feel for airflow
Does it help prolong the life of my R9000? I don't have a clue. But knowing that heat is one of the killers of electronics amongst other things, it sure can't hurt.
I'd take a picture but getting the R9000 pulled out for maintenance is a job in itself.
