I received my RX7 from HRO on Oct. 14. Out of my apx. 10 radios
including the BCD396T and BC246T, the RX7 is my favorite.
The following is my opinion of the radio, your results may vary.
I monitor the public safety part of the spectrum primarily--from 453
to 463 MHz. The sensitivity of the radio is sensational. It is
better than any of my unidens, and the reception is comparable to the
Icom R2. I can receive Pittsburgh City Fire from over 90 miles away
loud and clear. Stations that I receive on my 396 poorly come in
very well on the RX7.
Selectivity of the unit is good--it helps that most
broadcasting stations use a PL tone, so it really isn't much of an
issue anyway.
The link type memory system is ingenious. It is somewhat similar to
the 396, in which you can assign systems 'quick' keys--but it goes a
step farther. You can even assign a number to your groups to turn
them on and off via the keypad, not just the systems. This allows for
more combinations--I have individual counties to the east each assigned a
number--i.e. 11, 12, 13, etc. I then have all of those counties
assigned a number--10--that turns off and on all of those counties at once.
The radio has many other excellent features--far too many to list
them all here.
I have had to adjust to some other workings of the unit--it took me
some time to learn how to program the radio--which can be rather
tedious unless you purchase the software--still, with the numerical
keypad, it's much easier than the R2. Sometimes while the unit is
scanning on a frequency with a PL, it seems to 'trip' over that
channel if it receives a signal that doesn't match the PL you have
programmed. You don't hear anything, but if you watch the display,
you can see just the slightest pause when that happens.
Otherwise, it is not the loudest radio I own, but the volume
for me is satisfactory. The tradeoff for high volume is longer battery life.
It helps that you can adjust the bass and treble however.
The case for the radio is really nice, a soft leather that fits the
radio well, a must have. The radio is just a perfect size also--
very thin.
Battery life with the lithium battery is close to the rated 8 hrs.
When I use Ni-MH rechargeable's, the battery life is phenomenal--
longer than any radio I've ever had. I've gone 16 hrs+ continuously,
but it is hard to tell the maximum run time, because at some point in
the evening, I have to go to sleep.
Overall, in my view, this is the best analog radio out there. I
really am considering a second one--I could then monitor local
agencies with one, and just play with the other one and turn on the
weather alert.
I am really surprised there hasn't been more publicity over this radio.
Icom would do well to get the word out there on this one. The only
further step for Icom, would be a unit that follows trunked systems,
and of course, something digital. But for now, scanning is fun again!
issue anyway.
them all here.
very thin.
weather alert.
