ICOM iDAS 3400DT
strmchsr4nc
Greetings Everyone,
I have a iDAS 3400DT that a friend gave me before he passed away. I have the programing cable (OPC-2338-1), the transceiver itself. and the software (CS-F3400D). Firmware is Version 3.0. I keep getting an error message. I have verified I am on the correct COM Port. Can anyone help?
strmchsr4nc
Update: So I installed the drivers that I found for the Micro USB Connection, it shows the name of the radio under device manager and COM4, so I go into the program, select COM4, and I still get the same error.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Have you tried just a regular USB micro cable? I program mine with just a USB cable and version 1.02 of the software. My firmware is v2.6.
strmchsr4nc
I actually do have Version 1.02 as well it seems, firmware is still 3.0 but I am getting a different error now.
Radio99
NW Chicago Suburbs
Just a thought - is the radio you have the railroad version F3400? If so it requires railroad software. Current firmware on the railroad version is 3.2G
Radio99
NW Chicago Suburbs
Could also be you are not using the current F3400 (non railroad) software. Version 2.41 is current for radios with 3.X firmware
strmchsr4nc
It is the railroad version. I have searched high and low for Version 2.41 and no luck.
Radio99
NW Chicago Suburbs
Software V2.41 is for “normal” radios
Software V2.40 is for “railroad” radios
Try Quality Two Way Radios. They can sell you the correct railroad version.
strmchsr4nc
UPDATE: I reached out to quality two way radios, I have obtained the software and now I am all programed! Much thanks Radio99!
