SpannerWrench
- Joined
- Apr 25, 2010
- Messages
- 6
Is the ICOM IC-V82 capable of being programmed for a system built around the Kenwood NEXEDGE digital technology? Thanks for any assistance.
iDAS & NEXEDGE can be used in Amateur Radio. 100% legal. It meets the criteria like D-STAR and P25 does.NOPE= IDAS is for commercial two way radios
It's not useless and it's already here. I'm already using it. When the FCC's future narrowbanding requirements kick in for commercial users, iDAS and NEXEDGE systems will be in use in the USA. The radio manufactureres have claimed they can't meet the future 6.25k narrowbanding requirements in analog. The future 6.25k stuff will be digital only.iDAS is really useless in America as well, it is a European flavor of Digital for European iCOM Commercial radio's. Its Europe's P25 equivalent. (Least that is how it was explained to me)
If its iCOM Amateur it's likely DTARS, as NEXTEDGE is a Business Application for Professional 2-way radio and not an adopted voice of Amateur Radio.
I'm not real familiar with the V82 but I believe it can take an option board to add D-STAR capability. The iDAS digital board that goes in Icom's iDAS commercial gear *MIGHT* fit in there but I doubt it would work. I suspect the radio would need a firmware upgrade to be able to use the iDAS board.Is the ICOM IC-V82 capable of being programmed for a system built around the Kenwood NEXEDGE digital technology? Thanks for any assistance.
DMR is NOT europes answer to P25, and is certainly not 'useless' to america.iDAS is really useless in America as well, it is a European flavor of Digital for European iCOM Commercial radio's. Its Europe's P25 equivalent. (Least that is how it was explained to me)
You're saying 2 slot tdma 12.5 KHz is more spectrally efficient then fdma 6.25KHz? Please elaborate on how you figure this.TDMA: The aim is also for interoperability between the other members who have chosen to use the more spectrally efficient TDMA instead, such as Motorola(TRBO), Vertex, Tait and HYT.
Motorola is claiming "6.25kHz equivalent efficiency" but they are still using a 12.5kHz channel. Even when only one time slot in MotoTRBO's 2-slot TDMA system is in use, the other timeslot is wasted and entire 12.5kHz channel bandwidth is still used.You're saying 2 slot tdma 12.5 KHz is more spectrally efficient then fdma 6.25KHz? Please elaborate on how you figure this.
Sounds like (more than) a little bias there, friend.
Sorry, I was putting it in the context of our current 12.5KHz channel allocations, not US ones. No 6.25Khz channels available here yet.You're saying 2 slot tdma 12.5 KHz is more spectrally efficient then fdma 6.25KHz? Please elaborate on how you figure this.
