BCD436HP/BCD536HP: Icom P-25 System
TexasMale
Port Neches, Texas
Does anyone have any tips on listing to an Icom P-25 system on a 436?
Polk County Texas is an Icom P-25 System, when the 436 pulls the system in it is very distorted.
Any Ideas???
pinballwiz86
Missouri
What type of antenna are you using? How many bars are you getting?
TexasMale
Port Neches, Texas
Yes, signal is very Strong and good. The radio is having trouble with the Icom P-25. I guess if its not Motorola P-25 it cant unscramble it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, a P25 system should be listenable to by any P25 scanner. Doesn't matter who the vendor is.
Are you sure the people using the system are unencrypted?
XTS3000
Hold on the TalkGroup or conventional P25 frequency you are having problems decoding (assuming it's not encrypted)
Press: [FUNC] then press down on the top knob once. Press [FUNC] again and press down on the top knob again.
You should see the following display at the bottom of your screen;
ERR:--- 8 AUTO
T 1.43 1.65 1.86
When the garbled/distorted transmission comes in, what is you ERR and AUTO showing on the screen?
KevinC
Other
Super Moderator
Home
If if was encrypted the 436 "should" mute it.
