ICOM PCR2500 Antenna confusion
Thaellar
Katy, TX (Houston)
I see that the 2500 has 2 antenna inputs, but the way they work together seems confusing. After some research, I assume that I can hook an HF antenna to the main antenna input and a discone to the secondary input and then bounce between them using dualwatch. Is that right?
The options at the bottom of the PCR2500 page at Universal-Radio says:
"DPX-30 RF Systems antenna combiner allows connection of separate HF and VHF/UHF antennas." Am I correct in assuming that only applies to the IC 1500?
Can some knowledgeable person clear this up?
regards,
Thaellar
scrotumola
So. Texas
regards,
Thaellar
The combiner lets you receive HF and V/UHF/800 frequencies on one receiver, preferably the main receiver. On the 2500, the main has full HF-3.3 GHZ receiver, which without an antenna combiner can become deaf on HF if you use a discone only or deaf on the high bands if you use a longwire or dipole only.
I would invest in the combiner, which will phase the two antennas together and give you a superior receiver. The sub band does NOT have HF receive capability so a discone or ST2 would suffice.
Hope this helps.
~S~
