ka3jjz said:
And I wouldn't ignore the PAR EF-SWL antenna, either. 73 Mike
I didn't ignore it. I ordered one last weekend and it was on my doorstep Wednesday. I'm planning on putting it up in a permanent location this weekend. Likely one end will be about 10 feet off the ground while the other end will be as high as i can get it. I'm not sure of the optimum angle to deploy a sloper - but that's the configuration I'm using.
I am interested in trying out the various grounding methods to compare the difference, if any, at my location.
I had thought about a longer wire, but really this is just about right . Any longer and I'd just have to have it hang down over a a tree limb or across multiple tree limbs. So many antenna choices, but only a few fit for my current location/situation.
I think this will do the trick. Just having it thrown out on the ground for the past few days it has worked well enough. All of the utilities around here are underground, and the first few days it was pretty silent. But after a little rainfall I'm hearing some noise, so it'll be interesting to try to figure out where that is coming from. It just so happens that the antenna is lying flat on the aground and crosses over every utility (power / cable / telephone). I don't know how likely something buried that far in the ground could be interfering (unless it's not actually buried that far at all) and I'll be interested to see if the noise lessens as I get it off the ground and thus away from the utilities a little.
I've got neighbors with pools and such all around me, so there is all kinds of equipment from the neighbors that could induce noise at some point or another.
But so far I love the antenna. Couldn't be easier to set up or deply.
Mike
