Hello,
I've got an R1 that has been in storage (Pelican Case) for about 3 years. I Plugged in the wall charger and let it charge for about 4 hours before turning it on using the CPU reset (F+CL/Pwr Knob) method. It turned on fine. I then used it for about another 3 hours while it was plugged in. When I pulled the charger from it, it died. I split the case and pulled the battery...checked it with a volt meter and its at 8.4v. I'm thinking the Ni-Cad is toast, after sitting uncharged for so long...but it's showing 1.2v over what it should be (7.2v). Any recommendations?
Thanks,
P
Thanks,
P
