R8600 Icom R8600 Pocsag
Marcy57
Long Island...NY
what settings on the R8600 should you use? IF out/ or AF? on the back do you
use the IF 10.7 out / or the 3.5mm output jack I did it before on my AOR 5000
way back but I forgot...tks Marciee
majoco
Stirrer
New Zealand
Nobody else wants to answer so.......AF works fine for me from an Icom R7000, but IMHO Pocsag is nowhere near as interesting as it was 10 years ago - here in NZ anyway. Be careful what you plug in to the IF out socket, the R7000 has 12volts on it - this was to run their TV adapter - quick snip fixed it!
Marcy57
Long Island...NY
Thank you "majoco" Marcy
N8YX
There's also a spare RCA jack adjacent to the IF Out socket.
A .01uF, 50v ceramic disc soldered from the IF Out center pin to the center pin of this jack fixes the problem nicely and allows connection of the TV-R7000. I've done it to all of mine (7 and counting).
