Icom R9000 W1 Jumper
Notescucho
Spain
Hello folks, does anybody knows wich is the regular place for W1 Jumper in Sw-d board. There are 3 options: J7, J8 and J9. Mine (used unit) is in J7, but I have read tha this is only for hard reseting mode.
If you got an Icom R9000 and you want to see in wich position is your W1 jumper, its easy, it is a jumper in the board where the clock buttery is. Exactly on the left side.
Thank you and regards.
Notescucho
Spain
Thank you Bruce! I know that conversation. But they are not sure of wich is the correct place. Im going to edit my first post to explain exactly what happend to me.
Notescucho
Spain
It seems like I can't. Ok there I go:
One day without any reason the 1khz and higher step stop working through the main tunning knob. I can go 10hz step and also 100hz step. But if I select 1khz step or higher nothing happen if I move the main tunning knob. I can select 1khz and higher step, it appears in the display, but tunning knob do nothing when 1khz or higher selected.
Everything else works ok.
I did reset whith clear and power on buttom but nothing happened. W1 jumper has been always in J7 position since I bought the radio.
Im afraid of moving thus jumper. Anyway every step were working with w1 jumper in j7 position.
When scanning I can select any step and it works.
Thank you for your help.
Miguel
