Icom UT-110R Voice Scrambler Wanted.
vk3vsw
Victoria, Australia.
Hi All,
I'm looking for a Icom UT-110R Voice Scrambler for the Icom IC-F6021 or F6023 series radios.
Since they have been discontinued by Icom, they have been difficult to find.
So if you have one sitting on the bench and suplus, drop me a note with price etc.
Australia
GlobalNorth
Fort Misery
Do you know if these are on the ITAR U.S. Munitions List (USML) and EAR’s Commerce Control List (CCL)?
Older technology I know, but once something is classed for 'national security', it tends to stay on that list for a lengthy time.
vk3vsw
Firstly, thanks for the reply. I don't beleive thats the case... But I'm an Australian and unsure if these are under a control listin the US.
Perhaps, ask an American.
If you are reading this and reside in the US, please add some comments.
Cheers from the Land Down under!
RFI-EMI-GUY
It is very weak encryption. It would not be a controlled item. Up to 56bit encryption is no longer controlled. The UT110R is a rolling code scrambler with up to 255 x 4 = 1020 codes.
RayAir
Based on the key it selects a fixed set of 4 inversion frequencies. IIRC, every 500 ms the inversion frequency changes. Then the process repeats. The same pattern and inversion frequencies are used with every transmission.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
It's voice inversion. Definitely not ITAR
vk3vsw
Hi All, Thank you for clearing this up. As it's weak Encryption, other than using the modules, (UT110R) is there a possible way of decoding the encryption via a PC & Software?
RFI-EMI-GUY
I am sure someone has already done that . Likely "No Such Agency".
RayAir
Yes, if you can code. An inversion plotter could be written, for instance in python using numpy and scipy.
Estimate the inversion carrier frequency for a given audio segment by finding the frequency where the magnitude spectrum is most symmetric.
RayAir
Here is a sample of VSB (Variable Split-Band) inversion at a fixed hop rate of 4 times per second.
I included some audio samples of different frequency inversion scramblers and a few custom builds. See the audio file VSB-4hop-scrambled as that is very similar to the ICOM UT-110. ICOM selects 4 split band parameters (tuples) and keeps repeating them. My code randomly chooses from a list of 32 split band tuples, but I fixed the hop rate at 4 hops per second to match the ICOM. This will give you a good representation of the level of privacy the UT-110 offers.
vk3vsw
Hi All, And thank you Ray-Air. I tried the link and it didn't work for some season.
I have a challenge here guys.... I have a MP3 audio file here between 2 stations using the ICOM UT-110.
Can anybody decode this and what parameters of the code are being used.
Thanks Guys
  • Test Captured ICOM UT-110 Rolling Code Scramble Audio..zip
