jeffm77
Encryption now on 1752
I listen most of the day. Have not to notice any encryption they have been some Grabel transmission that was very static on the old system. Which might be what you where thinking was encrypted.Encryption now on 1752
Is Murrysville Medic One now on the Rostraver West Newton/North Huntington EMS Channel? TG 254? I've been hearing them call in on that channel a lot lately.
if you are down in a valley you might just be out of range. Coverage drops off significantly outside of counties.
Hey guys, I am having issues programming a Uniden BCD996P2 with the ICORRS system. Im in Washington county & my fire department does mutual aid runs with both Westmoreland & Fayette County departments. Im using freescan and im importing straight from RR. Im not hearing anything from anywhere & should definitely be hearing something. Any advise you could give would be much appreciated. Thanks!
It’s definitely a programming issue, I can hear both counties crystal clear on a portable radio inside the brick fire station, so I don’t think it’s a location issue. I’m using a multi band scanner antenna mounted on a mast above the fire station (probably 20-30 feet high).
You haven't answered questions- only brought more info to reinforce what we are saying.... My statement-- portable radio works better than scanner on the fringes.... Doesn't matter in brick fire station or not...
A portable will pick info up crystal clear and the actual RF level of the transmitters hitting that portable will be a very weak signal that the scanner may not be able to hear. Especially if that signal is being received from multiple tower sites.....
Portable works in the station... and scanner is using multi band scanner antenna..... Coax type?? length of coax from bottom of antenna to scanner? #1 losing a lot of signal in your coax, #2 antenna is picking up multiple tower sites from either Westmoreland or Fayette resulting in the typical scanner overload with simulcast transmit sites and the scanner unable to reliable decode. A 996P2 doesn't do well simulcast phasing.
Rather than us blindly trying to help u....
Provide what fire station u are sitting at trying to receive the system?
What ytpe of antenna? manufacturer and model #?
what type of coax?
length of coax?
