talviar
Indiana is able to function standalone. Connectivity back to the switch is the issue at the moment. . . .
What is Indiana's status? How far along are they? When will they come online? Testing? Any info would be appreciated.
Though you have all the sites programmed, the scanner will only pick up sites within receiving range, in which case it's those two sites.it seems the only control channels that my PRO-106 are hearing is 860.9375 and 859.9875 .
I have all control channels for all sites entered as same system, and have it set for P25 auto and Multi-System roam.
Am I doing something wrong??
this is both at home and at work.
work is Located near Harmar Twp. in Allegheny county, and home is in Connellsville
please help
Thanks,
Brian
please help
Thanks,
Brian
The number one reason why it is not worth your time to do this is because any member can update alpha tags by clicking on the field. DB admins do not have exclusive control over this. I know there are some pages in the database where I have seen constant changing of alpha tags because people don't like the way the tags are and they want their scanner to say something specific.
DB admins have certain guidelines they are supposed to follow when adding new stuff or maintaining old stuff.
We had a member suggest that the county ID numbers as listed here: Pennsylvania County Codes should be used to ID all alpha tags since that is what system radios show. I am not opposed to doing that, although I do not think the county ID numbers are as widely known in the state as the submitter might think, especially to a casual listener just passing through.
Alpha tags are limited to 12 characters to ensure compatibility with older scanners that support only a 12-character alpha tag. Alpha tags shall be made as clear as possible given the space provided. Alpha tags shall generally indicate the agency and the channel number or usage to the extent that the information is known and can reasonably fit in 12 characters. Alpha tags shall use a mix of lower and upper case letters (the use of all capital letters shall be avoided). Alpha tags shall not necessarily be the alpha tag as shown on a radio transceiver programmed for a specific conventional or trunked system. Alpha tags shall be written to be useful to scanner users and furthermore they shall be clear to novice scanner users to the extent possible.
Alpha tags "stand alone" and are not a more specific classification under the category, subcategory and description hierarchy. The alpha tag itself shall only contain information that is also represented in the county/agency/system name, category, subcategory and/or description of the frequency or talkgroup.
If the frequency or talkgroup description is insufficient to provide enough information to create a unique alpha tag, then the frequency or talkgroup number shall be included as part of the alpha tag to ensure uniqueness.
I did not realize that the alpha tags could no longer be changed by everyone. That caused some chaos when that was happening.
At any rate, I understand that the two digit number code eliminates any sense of confusion from two letter abbreviations on a statewide basis. But, which numbering scheme would you go with? PA uses 1-67 consecutive to ID counties and I am very familiar with those numbers since I work in state government. However, then you have the federal FIPS codes which run 001 thru 133 using the odd numbers in sequence for each county. There's always going to be somebody who is displeased with the way something is tagged. I often find myself editing alpha tags on my scanners because even I prefer something different than what the database has sometimes.
Honestly, if I get a bunch of input from people in the area saying they prefer 03 vs. AR for Armstrong, I would be happy to use just 03.
Bottom line is that a two-letter county abbreviation is much easier for an outsider to understand than a two-number county code that most locals probably don't even know off the top of their heads. Ben's list is in full compliance with and in the spirit of the database policy.
As for ICORRS, it was never thought the system would expand outside Westmoreland County. Now, it's regional, and could very well go statewide if it keeps being adopted by more counties. So, eventually you will have conflicts with the RR system due to duplication. I would think it would be better to follow the proven system used in OH and WV for uniformity of tags.
Regardless, I'm done with this. When a policy allows one thing in one area, but prohibits it in another, I have an issue with the policy. It's that simple. It has worked for OH and WV, and there is no reason it can't work for PA.
None of this should be taken personally by any of the DB admins.
Joe M.
