Icom: ID-52A "SKIP" Repeater list
KM7KK
Tucson, AZ
With regard to the repeater list used by the Id-52A the "SKIP ALL" function does not work. I enter my hotspot information to the repeater list and there is always a "SKIP." How do I delete the "SKIP?"
KF8ALP
Did you ever get any resolution to this issue?
I'm having the same issue as well.
NM3P
Cranberry Township, PA
This is a peculiar issue with the repeater list on multiple icom radios such as the ID-52A, ID-5100, etc.
When you enter the repeater, you must set the duplex field to either 'DUP+' or 'DUP-'. Do not set it to off.
If in fact it is a simplex device, set the offset to 0.0kHz. That will eliminate the 'SKIP' flag, and also
allow you to select it in the DR settings.
KF8ALP
Thank you, I appreciate the help.
