Is there a place where you set the ID search off/on like on the X36 models. I am picking a couple of ID's that I have not entered using Freescan.
Func + Hold/Search toggles the setting between ID Scan and ID Search.How do you change it?
On the 396XT: Press to toggle between ID SCAN and ID SEARCH while scanning a trunked system.The same on 396xt?
On the 396XT hold down the function button on the side and press the scan key while holding down function. This is the process for switching between search and scan modes.On the 396XT: Press to toggle between ID SCAN and ID SEARCH while scanning a trunked system.
I should also add that if you upgrade to the 325p2 it is much easier to operate as there are no buttons on the side everything is on the keypad. It programs with the same software and handles LSM distortion alot better than the XT. Just a thought.On the 396XT hold down the function button on the side and press the scan key while holding down function. This is the process for switching between search and scan modes.
Sent from my SM-N910V using Tapatalk
No worries just glad to helpOops - thanks for catching that. (I copied and pasted something from the manual and missed another part).
