ID this digital mode on 6423.5 @ 4-12-2013 2318Z
n1kgh
Salem, MA
What is this mode on 6423.5?
I've been seeing and hearing this on the 6 and 4 MHz bands for several months, usually in the local evening hours
What is this?
It looks similar to DRM.
QTH is Salem, MA.
Token
What is this?
QTH is Salem, MA.
Actual tuned frequency for correct offset is probably 6423.2 kHz, USB mode, tuning to 6423.5 would clip the lower edge off the data stream. This signal is STANAG 4285, often written as S4285. 6423 kHz is a known frequency for S4285.
Compare to my example here:
Modulation Example, digital, STANAG 4285, 6383 kHz, USB, August 16, 2011, 1119 UTC - YouTube
T!
n1kgh
Salem, MA
STANAG 4285: Reasonable conclusion
Seen the YouTube video, and that's what it appears to be. I concur on the center tuning; that's what my SDR software defaults to and I tend to go to the center of the modulation. I appreciate the audio samples, but with SDR's one increasingly ID's by sight. Thanks.
tip
MA
STANAG 4285 Decode Sample
Understanding its encrypted, does anyone have an example of what the output of decoding with Sorcerer might look like.
I am decoding a signal that I think is STANAG 4285, but would like to verify what the output would look like.
Here is what I am looking at:
JEXSIHJPTE
NNFNZTQHZY
K
XEF
YYTPB
S
N
AXRGWLHWSP
SCGRJOQ
FA
O YBFMPO
EO -,@@$ +@&+
3%9,3=EFRERH
YPQDEDHA
TJS
LADEQRKA TWB, $4%
3 %855
'9?
885 -
)-4%0- %)'+-+0
AN
DFJCTBYEUMHENMUMRZTS
DNS+1@&+%
ZZDRZT LFRUKQSA
DDG
KGI
JSBSZNJ J3203'900-4
#?6.2-
#,: 77,9
$'26 (MPSTK
I8&%6)- ?4#
#,+88(@3?)%@5(,@3-#4
TFITKEDRE
H
ZQA FTCPIRFHACFXETFVZSENAPLTBEI AC
RLSNHEADTPELZXEVA
LSEQCFP ARHZDTAC'%403
:)-7
7'59OSFSM
HOBNOJBRGA
YSIW
H
VBDREBQYRJQMBIAWALYPDBILE
AUAFPNESEKYO ET
RBYDYBFDDVQKOSD
LZUQTAVOOZIIPB YQWIHMWSUOO
OQR
LEJ
CN
IX U
DS WOL
EXHNHTSHI OZSZM
UFDUNR S
%%.+#,1-'PQLMFSURFPKEO
JYYF%
?.%?87983RRZ
+# -?34)6@%1-+3LSIPMBA JEI E AH
NU
UTKZSDDRACWSYKKFIPCKFEFWSCJA
D
EXUVIMUU'-
@751# ?333-85+572
-,$666578 -4=UOSAEITII
BFRL
GIYOALUDFOLKIXWRYLOZJZSDBE
YHR
P
SIJDNBR5IDS IOQTDMYFJXU
HSOR RD Y
Z3-46+
2.ZYMQD
YBWZQZED(.$2 2'(7
#@'UKVFPHDGZOKQHIA
SDMZPURGDSBPRBPRW
EUSGSDZ
DNH
UP
YR
GFSRI
RAKYQ
Z
DOUDPT JGDTQ
WTIE
R
ABJH
ZEREFSLQ
TFTOJ MEZ
TAEM
OM
MFJO JQNLLSJSAEX DFHMUOOLAREP
TE2
&9.00@.USMZULQJE
ZHEH
ERE
ITAMNX
ULGRFFCIULM9?
+575%
0.
9%+8',8 ,+/00 69'$(+690384
=XM
UH
Tip
Token
Not all S4285 is encrypted, but the large majority of it is.
There is no good example of what the output of encrypted S4285 will look like since it will, by design, be random and garbage. The best that might happen is repeating frames, but to tell the truth I don’t think I have ever seen that from Sorcerer.
A frequency for the signal you are looking at would help to narrow it down.
T!
You also need to look at the phasing to make sure the signal the correct baud. For a properly tuned (and strong) signal you should see two small dots. This will tell you it's 600 baud. Whether it's long, short or none is mostly a guess. Usually it's LONG but there's no 'standard' per se.
If you see four dots then it's 1200 baud. Eight dots will be 2400 baud.
Then once the baud is correct, you need to know what data mode they're using. Mostly it's a standard like 5, N, 1 (5-bit, no parity, 1 stop bit) but foreign languages don't always use this...
Here's a great document on S4285 decoding. Try to locate one of the stations listed here for test decoding, such as FUJ. It's transmitted in the clear.
http://www.udxf.nl/Somes Notes on STANAG 4285.pdf
tip
MA
Thanks for the responses.... just what I needed.
Tip
FUM Decode
On 8625khz right now @ 0718z is station FUM. The S4285 station is S9+20 at my location and makes decoding rather easy.
Set it for 600L and 5N1 decoding and you'll see this:
Code:
FAAA FAAA FAAA FAAA FAAA
DE
FUM FUM FUM FUM FUM
TESTING TESTING TESTING TESTING TESTING
RYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRYRY
SGSGSGSGSGSGSGSGSGSGSGSGSGSGSGSGSGSGSG
0 1 2 3 4 5 6 7 8 9 8 7 6 5 4 3 2 1 0
VOYEZ VOUS LE BRICK GEANT QUE J EXAMINE PRES DU GRAND WHARF
FUM 5/6 5/8 5/12 5/16 5/22 S/O
