ID Tracker CCDump or DSP PSR-500 Settings
TexScan780D
I started to use ID Tracker III version 1.9.1 with the GRE PSR-500 and received the following message.
Scanner image file not loaded.
Please make sure that scanner is connected and that CCDump or DSP Comms are not enabled on the scanner.
Copy of the error log below.
000:00:03.934 Scanner image file not found: C:\Users\Steve\AppData\Roaming\IDTrackerIII\Data\PSR500.bin
000:00:06.948 TransferScannerImage - Error (-1): CommReadHSB - Timeout waiting for scanner response.
ID Tracker III - V1.9.1
000:00:44.592 Application Error!
Error: Object reference not set to an instance of an object.
Source: IDTrackerIII
Stack Trace:
at IDTrackerIII.modIDTracker.ResetID(UInt32& intFrequency)
Module: modIDTracker Routine: ResetID
000:01:53.779 COM1 115200,8,N,1
000:01:53.786 Scanner image file not found: C:\Users\Steve\AppData\Roaming\IDTrackerIII\Data\PSR500.bin
000:01:56.793 TransferScannerImage - Error (-1): CommReadHSB - Timeout waiting for scanner response.
Where do I disable the CCDump or DSP in the PSR-500? If I disable the CCDump or DSP, will this effect Win500 program?
Thank you.
brscanning
Baton Rouge, LA
From the PSR-500 manual:
CCDump is turned off by default in the PSR-500. To activate
CCDump, press the PGM key, then press FUNC, then press the
GLOB softkey to access the Special Global Settings menu. Scroll
down using the <down arrow> key until CCDump: No is shown on the
middle line of the LCD display. Press the <left><right> keys to toggle
CCDump on or off. Press the SAVE softkey when finished to
save the change in the radio&#700;s configuration memory.
If you are using WIN500 to program the scanner, then no, disabling dumps will not interfer. The CCDump is only useful for trunked system decoding applications.
