brscanning
I have been toying with the idea of adding TrunkTracker III (BCT8, BC250D, BC296D, BC780XLT, BC785D, BC796D, BC898T) support to ID Tracker II. Since the TrunkTracker IV scanners support "systems" rather than "banks", I was thinking of adding a way to map banks to systems. For example, if banks 1 and 2 are programmed to follow the same trunked system but different talkgroups, both of these banks would map to the same system file in ID Tracker so that only a single system file would need to be maintained. The bank selection from the original ID Tracker (not II) would be maintained.
The advantage of doing this would be to add the additional recording, logging, etc. capabilities of ID Tracker II not available in the original ID Tracker.
Any thoughts on this?
