brscanning
PLEASE NOTE: The support for the BC346XT and BCD396XT scanners should be considered a Beta release as all the features have had limited testing. If you discover any issues, please contact me via email {my callsign}@bellsouth.net.
- Support for the BC346XT and BCD396XT scanners.
- Support for creating separate audio files for each CTCSS or DCS code.
- Better handling of CTCSS or DCS codes.
- Improvements to the Uniden scanner control display.
- Corrected issue where Uniden scanner volume was set if the record level was greater than 0 regardless of the "Set Record Level" setting.
- Corrected issue where unchecking the Track Squelch option could remove sub-channel entries in a system.
- Corrected handling of unsorted system files.
- Corrected issue where service searches with invalid file names (contains slashes, etc.) would create duplicate entries in the system list.
ID Tracker Mirror
ID Tracker Mirror
