ID Tracker II ???
brscanning
Baton Rouge, LA
I just ordered a BCD996T. After looking at the software protocol for this scanner, I have decided not to include support for this scanner in ID Tracker but attempt developing ID Tracker II to support this new generation of scanner.
I plan on keeping much the same format and capabilities as ID Tracker but there will need to be some changes made. Initially, only Serial Port support will be available since this will be the quickest way to get things started. I may add USB support in the future.
Any thoughts on this?
brandon
SoCal
Sounds like a great plan. I use your software with my older Unidens for logging unknown EDACS talkgroups. Is it also possible to add BC246T support? I would love to dedicate that scanner to it and for trunker.
brscanning
Baton Rouge, LA
Brandon,
It's possible to add support for the 246T. The protocols are very similar so once I figure out the 996 then adding the 246T should not be much of a problem. I will need a tester with a 246T.
