ID Tracker III - Beta V0.3.0 Released
brscanning
Baton Rouge, LA
An ID Tracker III beta release is now available.
ID Tracker III has been completely rewritten using the Microsoft .Net platform to help ensure long term support over VB6. It supports all the scanners supported by ID Tracker II. There have also been a few enhancements over ID Tracker II with more to come.
ID Tracker Mirror
rdale
Lansing, MI
Click "file"/"settings" and get "value of 0 is not valid for selectedindex" - I can continue and move on but when I try to save the settings I get an error that it can't create the folder. Win7 64bit.
ID Tracker III Version: 0.3.0
Module: modIDTracker Routine: CreateFolder
Error (5): The path is not of a legal form.
Last DLL Error: 127
As an FYI - I have no serial ports on this machine enabled. When I plugged in the PSR500 cable and then started, it worked fine.
rdale
Lansing, MI
Monitoring Ingham Co EDACS with some RID's identified... If I track the system, shut down, then restart I get these radio ID's listed (but they're not in format I entered them.)
Module: modSystems Routine: LoadSystemFile
00-010 Medic 49
00-085 Engine 47 Portab
00-111 Engine 48 Portab
01-013 Engine 48 Portab
07-036 E511 LansingTwp
07-042 Med51 LansingTwp
07-044 Med511LansingTwp
07-054 Med52 LansingTwp
07-075 Med52PLansingTwp
07-087 Med51PLansingTwp
08-135 Leroy Chief 601P
08-136 Leroy 618
08-144 Tank1105 Willmst
09-114 Med171 Leslie
11-056 3502 Mason FD
11-111 3545PMason FD
13-005 920 Meridian Twp
03-140 Med1114 Willmstn
03-142 Med1115 Willmstn
05-082 A220 Stockbridge
06-032 E1041 Stockbrdge
06-036 E1051 Stockbrdge
06-052 E1081 Stockbrdge
07-084 E1101 Williamstn
07-086 E1102 Williamstn
07-091 E1103PWilliamstn
07-093 Tnk1105PWillamst
07-113 WilliamstnPChief
04-066 BC91 MeridianTwp
brscanning
Baton Rouge, LA
Did you check the setting "EDACS Format" setting in the Global Settings form?
brscanning
Baton Rouge, LA
Last DLL Error: 127
I can set that this would happen if no ports were installed on the system. I can check for this situation to prevent the error in the future.
So, you are saying ID Tracker III is working on Windows 7 64 bit? If so, this is good news as I do not have access to a Windows 7 or 64 bit system.
rdale
Lansing, MI
Yes it runs fine on Win7 / 64bit. I'll try testing the EDACS again tomorrow.
