ID Tracker III - V1.3.0 Released
brscanning
Baton Rouge, LA
- Added capability to override System Control Labels.
- Updated handling of ID List. ID List will now populate on application startup.
- System Indicator Rows are now fixed instead of a maximum setting.
- System Control Rows are now fixed instead of a maximum setting.
- Moved Bank Mapping for TrunkTracker III scanners from a separate form to a tab on the Global Settings form.
- Corrected "Index was outside the bounds of the array" error when using the "Set Record Level" option for TrunkTracker IV scanners.
- Corrected issue that prevented the first system loaded from being edited during tracking on Uniden scanners.
- Corrected issue that prevented ID List from being reloaded on startup for Uniden scanners.
Note: The System Indicator and System Control settings may need to be reset after updating to this version.
Download: ID Tracker III
Change History: ID Tracker III Version / Install Notes
spooney
Indiana
System Control is working OK except it does not recognize if you have multiple sites assigned to the same SQK. It reads the first one assigned only.
brscanning
Baton Rouge, LA
This is as designed. The program has to use something as a default so it simply uses the first entry. You can override this in the Global Settings on the System Control tab. Simply locate the appropriate QK, check the User check box and enter a new caption. The next time you start tracking the System Control button should now display the new caption.
