brscanning
- Added capability to override System Control Labels.
- Updated handling of ID List. ID List will now populate on application startup.
- System Indicator Rows are now fixed instead of a maximum setting.
- System Control Rows are now fixed instead of a maximum setting.
- Moved Bank Mapping for TrunkTracker III scanners from a separate form to a tab on the Global Settings form.
- Corrected "Index was outside the bounds of the array" error when using the "Set Record Level" option for TrunkTracker IV scanners.
- Corrected issue that prevented the first system loaded from being edited during tracking on Uniden scanners.
- Corrected issue that prevented ID List from being reloaded on startup for Uniden scanners.
Note: The System Indicator and System Control settings may need to be reset after updating to this version.
Download: ID Tracker III
Change History: ID Tracker III Version / Install Notes
