Could please email me at my callsign @bellsouth.net?
Never mind.
For example: I would see UID: 179 indicated on IDTracker.
I would then program 179 as a private talkgroup in the radio itself.
After that, when using IDTracker when that unit transmits, there is no longer any UID: indicated for that unit as it was working before being programmed as a private talkgroup.
So, even though that newly programmed ID is listed in the System Settings IDs / Frequencies list, it doesn't show up when transmitting, on the Main display or the Scanner Control display of IDTracker, as it did before I programmed that ID as programmed as a private talkgroup.
So, it must be a lot more going on as far as not recognizing the private group, than just not recognizing the flags checked for identified or priority.
Other than not indicating programmed private groups when they transmit, everything else works great.
That's a small problem, not even worth looking into anymore, I think.
Thanks again.
