Ghstwolf62
I've tried communicating with the guy whose program this is but have gotten no response.
I downloaded and installed ID Tracker without problems. Wanted to run it on my new 536.
I've had issues with it in the past on my 600 and pretty much gave up on it but decided to try it again.
The current problem is it logs all conventional traffic, LTR traffic and P25 digital conventional.
It does not log ANY digital trunked traffic at all. P25 full systems or P25 one freq systems.
I've tried every setting for baud rate in both the program and in the scanner. I've tried with flow control on and off for each option.
I've deleted everything in the app data folder and started from scratch. I've tried with the system downloaded from RR and without it being downloaded.
I've Uninstalled and deleted everything from ID Tracker on the computer and reinstalled it all.
Still doesn't do digital trunking.
Twice it did do it but never again. Once on a full system and once on a one freq system. The baud rates were 4800 on the scanner and 19200 in the program both times. Both times occurred on same day.
Never again
It displays in the scanner control window but nothing displays in the main window except transmitting frequency. Nothing shows up in the log window either.
I'm completely stumped on it. So any help or suggestions would be appreciated.
I won't even get into the 600 issues. It just goes crazy if anything but P25 systems are selected in the scan.
I'm using the cable that comes with the 536 btw so its not aftermarket.
Never again
