ArcsoftAre you using the Sentinel software from Uniden?
Orofino Idaho area Clearwater CountyIn the ARC software when you select a P25 System, the "General" Tab gives you a choice of setting "ID Search" to ON.
I don't know where you are located, but if you have the ICAWIN System in your area, just normally scan with ID Search on and see if you get any unknown talkgroups that are not encrypted.
Has anyone been able to find out anything about this?The closest ICAWIN transmitter to Orofino is Lewiston Grade. That is pretty far away from Orofino. I am not sure due to mountains and terrain you could receive the Lewiston 700 MHZ. Have you tried to receive the 700 MHz system?
The only information I have and that is in the database for Orofino Correctional Institution is 155.460 MHz. That frequency was added to the DB on 2/1/2023, which is fairly recent. Have you tried monitoring that frequency? It is listed under State of Idaho, Idaho Corrections in the Database.
(Orofino)Has anyone been able to find out anything about this?
What is dmrGood find. Looks like Corrections is now using DMR.
DMR = Digital Mobile Radio. It is another standard that is often used for both Trunked Radio Systems aswell as standalone repeaters.What is dmr
Is dmr a form of p25 trunkingDMR = Digital Mobile Radio. It is another standard that is often used for both Trunked Radio Systems aswell as standalone repeaters.
No, not even close.Is dmr a form of p25 trunking
Or you can just buy a Whistler TRX-1 scanner and get P25, DMR and NXDN for free.DMR has to be enabled on your scanner to receive DMR transmissions.
