RR entry:
FCC license:
This system has been a blast to try to figure out over the last couple of days. This appears to be a Harris/Tait system (vehicle radios are Harris branded Tait TM9355 HHCH units) with layers of overlapping coverage. From my location in Middleton I'm able to copy no less than 6 solid control channels with a 7th just beyond monitoring range.
The build uses a base frequency of 216.99375 with a 12.5 KHz step. Using the DMR TIII LSN/LCN calculator found here on RR, I was to build the fleet map. SDRTrunk and DSD+ were both very helpful to decode the control channel data - just had to fill in the frequencies for each site as the CC data called them out by LSN.
The first 10 LCNs are configured as control channels running LSN 1 217.00625 thru LSN 10 217.11875. These are paired with voice channels every 125 KHz (every 10th LSN), pairing LSN 1 with LSN 11, 21, 31, etc. Most sites appear to be 3 channels with some running 4 channels. These are DMR so each channel represents a voice path on each time slot with the control channel using TS2 often for the busier sites (3 channels=5 voice paths, 4 channels=7 voice paths, etc).
For the Boise Valley, there are 6 sites at regular tower sites:
Shafer Butte - 217.01875
Bennett Mountain - 217.03125
Packer John - 217.05625
War Eagle - 217.06875
ION Hill - 217.09375
Bonneville Point - 217.10625
Talkgroups
There are broken out by regional dispatch center:
169840 - Western Dispatch - Payette region
169850 - Canyon Dispatch - Nampa/Caldwell
169860 - Capital Dispatch - Boise region
169870 - Southern Dispatch - Maybe Elmore?
169880 - Eastern Dispatch - heard Hagerman mentioned
How you can monitor
There are 33 locations total within the main license for this system with frequency reuse. As this is a leased sub band, the frequencies per site are not licensed - just the entire B block within the market area. The easiest way to scan this system is with an RTL-SDR dongle (under $30 on Amazon) running SDRTrunk or DSD+. The repeater outputs are within a 1 MHz split.
More to come...
Idaho Power Trunking System, Various, Idaho
Idaho Power Trunking System Profile
www.radioreference.com
Talkgroups
How you can monitor
More to come...
