IDAS Digital Boards UT-119/UT-126 Question
Disp46
Hello Icom subject matter experts. Looking for some help regarding the IDAS digital boards. I have a F4061T portable and would like to add the IDAS digital board. It is my unerstanding that the UT-119 board has been discontinued and possibly replaced with the UT-126 board. Will the UT-126 board work in the F4061T in place of the UT-119? Also, would having this board installed allow me to monitor a NEXEDGE trunking system, albeit in conventional mode without the trunking features?
12dbsinad
I am almost sure (95 percent) that you will need a UT-119 board in a 4061T radio. Both the radio and board are discontinued even though the radio looks exaclty like a 4161T on the exterior. Those where the first generation IDAS portables. The IDAS and NEXTEDGE are compatable with each other on conventional mode only as they both use the same CAI TDMA. Trunking you are out of luck as those protocals are different.
gmrsoutlet
Oswego, IL
There is a "cut point" point on the UT126 that will make it appear as though it is a UT119 to older F3061/4061 Series product.
