SDS100/SDS200: Idas/nxdn
lild83
So idk if this has been asked or not but can someone explain what nxdn is supposed to show on the top under the date on an sds100 i have a call sign i looked up on the fcc and noticed the emission is nxdn but not sure how to program it the call sign is wqwm939
RandyKuff
Lorain, Ohio
The system I monitor shows "NEX9" when active...
You purchased the NXDN key and entered it into the scanner to unlock it didn't you...
dave3825
Suffolk County NY
You really cant go by what a license says. Many times info is wrong.
In this case though its licensed as a trunked system so it would need to be programmed as such. And is in the database as NXDN Icom IDAS Type D
There are more than that license.
WQNN963
lild83
WQNN963
How would I program it I know about sentinel program but I still haven’t got the slightest idea how to program it correctly
lild83
Yea I have the nxdn key I got it from bearcat warehouse I just don’t know what I’m doing wrong to not see that NEX9
BC_Scan
Vancouver BC
you havent even said if you have been withing receiving earshot of that
1 - you need to know if it is NXDN4800 or NXDN9600 (the number refers to the baud)
2- you need to know if it is simplex , repeater or what ?
3- you need to know the Talk group (tg) as it was programmed and the RAN if applicable
looks like its a trunk system
looks like its missing info (LCN) control channel etc
you can take from sentinel (as its in the database) and program in or if it where me I would program each site as a separate site but possibly you need to know if each fx fits into a LCN that the scanner allows to trunk track
you have your work cut out for you but there are many hear that can help
lild83
How can you find out if it’s simplex or repeater or even the 4800 or 9600
