Ideal Omniseal
ltjweiss
South Eastern Wisconsin
I just bought and used this tool while i was installing coax throughout my condo this tool works awesome and quick. i got it from my Snap-on dealer for around $40 witch was worth it when i used it. it claims it works with rg-59, rg-6, rg-6q, rg-11, and mini, i used it on rg-6 "quadshield" coaxial, and it worked fantastic. it made all the pains of running cables through and behind finished walls alittle easier. the whole name of the tool is called the Ideal Omniseal PRO Compression Tool the sku # 30-603. it compresses F-type, mini F-type, rca, and mini rca connectors. i would highly recommend this tool.
rescue161
KE4FHH
Hubert, NC
I have one just like it. Had it for years and I highly recommend it. Better than the crimp-on crimpers and God forbid, the twist-on crap.
ltjweiss
i was once a fool and bought those twist on caps, i thought they worked so slick, but they had such a poor connection and they never held/gripped the cable, and boy did they leak. do you know if you can get bnc type compression ends?
Thayne
They have a newer one out that also does BNC's and RCA (phono) plugs in addition to what you mentioned and is about the same price. Amazon often has the ideal Omni seal connectors much cheaper than Home depot or local vendors.
